Repair Aluminum Rivet attached to seat
theat
All,
While repairing my 12' aluminum boat I found a leaking rivet. However, its the same rivet that connects my seat supports. Any ideas on how to replace and reinforce? I was thinking of installing a washer on the inside. Any other ideas?
jigngrub
Re: Repair Aluminum Rivet attached to seat
Pictures would be helpful for giving you the best advise.
theat
Thanks Jig,
Here are some pics, from below and above. As you can see the rivet is really worked and i can see daylight around the hole. I was thinking perhaps a screw and oversided washer, stainless steel with a nylon washer as I am in saltwater.
jigngrub
Yeah, stainless steel pan head screw (1/4"), stainless washers both sides, nyloc nut inside. Goop everything up with 3M 5200 marine sealant before installation, remove excess 5200 after installation.
