Shallowman
- Joined
- Oct 11, 2010
- 114
Re: Repair manual for 60 hp mariner - year 83 or 84 and water pump question
Thanks , My manual came in today. Looks like i got everything it says i needed to remove . The motor will be upside down in the morning
Thru the access hole i can let the pb blaster go down on the shaft . I can see a seal ( black rubber looking ) but can't see the splines at this point should i try to peal away the seal ? Either down so i can cut it out of the way for the pb blaster to into the splines more . My last hope after this is to try heat but i prefer not to try that yet .
I got some good marks on the lower end now so i may try to find a used one somewhere. Where can i find out what years/model lower unit i can use for mine ?
