79Merc80
- Joined
- Nov 22, 2007
- 673
Re: Repair or Repower?
You can take both powerheads off and put the older one (Off the Glasstream) on the newer mid tower. You can also take the engine end of the wire harness and splice it into the Mariner harness. If the Merc you purchased is the same ignition that you have on the Mariner, then you can take the engines internal wire harness and put it on the older powerhead. If the older one has a distributer, then you would need to make an adapter on the boat end of the Mariner harness.
Hope this helps.
Craig
Hope this helps.
Craig
