Repair shop NIGHTMARE!
Status
Not open for further replies.
Alwhite00
Re: Repair shop NIGHTMARE!
One, I sure as hell wouldn't take it back there, Lawyer will cost you more than the boat is worth, I'm thinking your third option might be your best at this point.
LK
catfishcarl99
well in the dryvit or stucco work i do first thing we do is cover windows doors and concrete. he should have put cardboard down to protect carpet ect.. obviously not a pro. if its still leaking ide say your up a creek without a paddle. maybe call judge judy. going to court over a $1500 boat is it realy worth it? bad deal but not a hell of a lot of options that wont land you in the jail house.
i do all my own work. i know you said time is an issue. nut i plumb, wire, roof, pour concrete, mechanic whetever it takes. i learned taxidermy myself. i wont pay for much work any more. my 98 pickup i got from my grandpa had plugs and wires changed by PROFESSIONALS a few months before i got it. well when it started running on 6-7 cylinders i changed plugs. 7 matched. 1 didnt. the one thats hard to get too. ya the dealership F ed him. and that fixed it a lil. after i replaced the few month old wires that looked old and dirty it ran geat. i dought the other guy changed the wires. i think he wiped them off. i had a time un buckeling the supports for them. i dont believe they were ever un done from the time it rolled off fords floor. if i do it it may not perfect but i know the job was done the right way anyway. let us know the story. ide made him sand off every drop of the rubber crap and said i wouldnt pay for rubbered paint. thats not the right way. should have been glassed. my guess he cracked it and sealed it 1/2 assed with the coating.
vintageglass
What did you originally take the boat to him for? Was it to replace the transom wood core or to fix a leak?
What brand outboard do you have? What type of controls? It may be something pretty simple.
I can't imagine what he could have done to make it not start or not shut down simply by removing the motor. On most motors its just a matter of unplugging the harness and unbolting the motor.
He most likely didn't have to touch the controls.
Where is it leaking water from? If it leaked before, and leaks now and there's no visible holes in the outer transom panel then its most likely either the two lower motor bolts or the rub rail. Both are common places to take on water. I'd expect that even the dumbest idiot would seal at least the lower motor bolts, if not, just do remove the bolts and do it. I'd find where it's leaking first. Put the boat in the water and look under the splashwell at the lower bolts, see if their leaking, also look at the bilge drain, make sure its not leaking. It would be pretty embarrassing to go screaming at this guy only to find out your drain plug leaks.
Its also an old boat, I wouldn't be the least bit surprised just the same if the wiring harness isn't brittle or falling apart just from age or corrosion. I've seen plenty that didn't survive removal after so many years. Take a close look at the control harness connection, make sure its clean and not corroded. If your motor runs a magneto, it very well may just be a bad connection that needs cleaning.
While I agree the shop was far from professional, there's only so much I'd expect from a $1000 transom job.
If he did indeed replace the transom wood and all the glass work was done properly you more than got what you paid for.
A real shop would have charged far more to do the job from start to finish.
As someone who on occasion will take on a side project to make extra money, I can tell you there's not a chance of getting a transom rebuilt for that kind of money here, I value my time far more than that guy does. I'd also insist that every loose item be removed from the boat and out of my way. I don't have room to store loose items like rafts, tubes, lifejackets, etc. while the boat is apart.
I would most likely at least wash down the boat when I was done but there's not a lot you can do about dust getting all over the boat since grinding fiberglass and sanding is messy, it gets everywhere. Anything short of taping up the whole interior would be useless.
Its just dust, it will blow away with a simple shot from the air gun, and the rest will vacuum up or wash off. Not a big deal.
As far as your decision to dump $1000 into a 1978 trihull, that's on you. Boats these days are plentiful, and there's plenty out there for cheap often in good condition. I have to assume you really like the trihull design and that's why you wanted to save that hull?
There's no way I'd go back to that shop. Besides, it sounds like more of a body shop or fiberglass shop than an outboard repair shop. If so, its highly likely they know little to nothing about motors. One of the best paint shops I deal with probably couldn't change a spark plug. And the same goes for most outboard repair guys, most won't touch fiberglass work or paint. To me its sort of like hiring a roofer to replace the shingles and wondering why your basement windows still leak.
I'd find the water leak first, then check the motor connections.
What year and brand is the motor? What type of controls?
Got any pics of the transom?
m.qualls89
Ill get pics when i get home. The motor is a 78 merc black max.
m.qualls89
When i looked at the drain plug it looks like regular caulk around it... Ill just reseal it and rewire it and hope for the best...
Here are some pics. Notice the BS inspection plate in the splashwell that was installed to tighten the bottom motor bolts. Here is link to pics. http://s1054.photobucket.com/albums/s497/Matthew_Qualls/
Ayuh,.... This is turned into a Whine thread,.... 'n is now Closed....
We know you got an Old boat....
We know you hired a fella that didn't measure up to yer expectations...
This is a Dyi site,... If YOU wanta fix it,.... We'll help ya through it....
This Isn't a "My mechanic is Ignorant" site,.....
Good Day,....
Status
