TheRussian
- Joined
- Jul 10, 2013
- 142
Hello everyone,
This is my first post and am excited to join this commmunity. I am a first-time boat owner so I am finding out many things the hard way. I have purchased a 1993 Ebbtide 182SE bowrider with a 4.3L Merc I/O (I think Alpha 1 Gen 2) and have only had it out a handful of times.
A couple of days ago I was navigating a local lake and failed to realize how shallow the water was at the shore. I was moving at a very slow speed and hit what I presume was a fairly large rock. There is no damage to the hull. I have examined the lower unit and did not see any cracks in it but the skeg is significantly damaged and so is the prop. After I struck the rock I was still able to get back to the boat launch without any problems.
My question is regarding a repair to the skeg. A local shop can rebuild it for $260CAD. I have found an alternative in form of the skeg guards that I would be able to "cover up" the nasty skeg with. In order to use one I think I will need to cut off piece of the bent skeg. I am really unsure on how to do it... Should I use an angle grider and just chop it off? I have tried to bend it back into place with two hammers with minimal success. Also, a prop rebuild is quoted at $140 and I think I can buy a new aluminum one for less than that online. If I use a skeg guard and buy a new aluminum prop my repair costs will be around $200 instead of $400.
Any advice would be much appreciated. Please see the pics that I attached.
