Repair UF wire
mscher
Is there a method to repair a cut UF wire re-seal and re-bury?
JB
Re: Repair UF wire
Dang! I wish I had seen that 15 years ago when I had a veritable plague of UF cable failures. I finally had to rip up about 300' of it and replace the whole thing. The main problem was that it was aluminum wire, not copper, and the various methods I used to try to splice patches in where the insulation had failed weren't any better than the cable itself.
The "new" house (10 years, now) has above ground feed.
i386
Re: Repair UF wire
Cool, haven't seen that one. 3M makes a lot of different splice kits for many applications. There's bound to be one for anything you might need to bury.
Bob_VT
Re: Repair UF wire
I have seen the telephone people use a similar set up except they had an epoxy gel that encapsulated the entire splice and not the shrink tubing.
i386
Re: Repair UF wire
Yup...
Well the one I saw wasn't epoxy but it is a two-part mix in this nifty bag that combines the two parts. You pour it into the splice box and tape it up with the included special tape. It congeals into a moisture proof rubbery stuff. You can dig it up later and service it. The gel sort of crumbles away in a nasty mess.
The other one I've seen is a small plastic box that closes like a clam shell. Both halves are full of a similar gel. You just put the splice in there, close the box, and tape it up. Pretty simple for a small cable. The aforementioned one would be for a a larger cable like 50-100 pair.
The_Kid
Re: Repair UF wire
An old telephone repairman told me this one. Get a tube of 100% silicone chalk and cut it in half and poke each end of the repair into the chalk. Cheap and waterproof.
