vegas_storms
- Joined
- Apr 24, 2007
- 37
Having some repair work done on 89 Cobalt 4.3L 175 with Alpha unit and am curious if these prices sound atleast in the ballpark.
Replacing with new
Bellows - very bad shape
shift cable - preventative since we're in there anyways
gimble bearing - grumbling when engine running and it grinded when spun by hand, i assume that is bad.
u-joints - water in the assembly along with 2 small fish
, U-joint had a decent amount of rust on it alond with water all through the needle bearings(think that is right)
water pump - preventative
impeller - preventative
Basically looked like a complete rebuild of the outdrive or close, all OEM parts not aftermarket,
also a complete tune-up on the engine.
$1200 for the transom kit, plus waterpump, impeller, shift cable and complete u-joint assebly, plus other small misc. parts.
$400 for the complete tune-up, replacing everything from plugs,rotor, filters,oil etc.
Here's some pictures of the inside after we finished a serious detail - Magic Eraser ROCKS.
Thanks for any info you can give me, first boat just trying to use what I learn from you guys.
Replacing with new
