lonewolf41
Thread starter- Joined
- Jun 28, 2013
- 174
I bought a 2006 Regal with a 4.3GXi-F and an SX-M. I knew when I bought it the engine needed work...possibly replacement. I got it home and began looking at it and it needs replacement. It was used in salt water and has been sitting in salt air (Florida) for quite a while it looks like. At least 3 cylinders had water/rust in them. Couple of questions. For the outdrive (which has a coating on it and looks good), is there anything I need to do to it besides change the gear oil? If it looks good and can pass the vacuum and pressure tests, can I just fill it up and motor on? I will of course be replacing gimbal bearing, bellows, etc, while I have the drive and motor off the boat.
Secondly, since I have to spend at least $2500 to get my motor going again (longblock, risers, manifolds and other misc. parts), I found a 5.0GXi-B complete for $3000. For a few hundred more I could upgrade with more power and be ready to go with less effort I think. I have about 8"-10" of clearance in front of the motor now and it looks like the engine mounting pads have about 7" more room in front of the current mounts. I am thinking it would be plug and play with new motor mount holes in the stringer. Anything vital/critical I am missing with this line of thought?
Lastly, why do they run raw water through the fuel pump? That is just one more thing to get eaten up by the salt water and have to replace. I don't know how the guys in Florida do it. I can barely keep my stuff going in fresh water.
Anyway, thanks for any feedback/suggestions,
-Keith
-Keith
