repairing a PVC
Pantharen
I have a PVC RIB, the PO wasn't kind to my boat, and there are a few holes that were patched with the boat inflated..
It is now deflated in my "heated" shop, and what is the best way to keep the area flat until the patch sets??
lncoop
Re: repairing a PVC
Depending on where the holes are you may or may not be able to keep the areas completely flat. Just be sure to follow proper patching methodology to the letter, especially the roller step. Once you've done that I'd just make the area as flat as possible and not worry about it. Wouldn't hurt to put some weight on it, but if you've done the repairs properly you shouldn't have any issues. This is assuming we're not talking about seams.
Pantharen
Re: repairing a PVC
none of the tears are on a seam line. There was one on the transom, but that was professionally repaired.
lncoop
Re: repairing a PVC
That's good. Should be pretty straightforward then. Be sure to clean all the old glue off and prep the areas really well, and resist the temptation not to let the glue dry long enough. I know I said it before, but follow the directions to the letter. Are you sure the boat is PVC and not hypalon?
Pantharen
Re: repairing a PVC
It is PVC, my Hypalon was a real POS, and I paid way too much for it.. I didn't fully realize just how bad of shape the Zodiac was, until I had let my brother borrow it, and he tried to roll it up, and the floor separated from the sides... You know, if you attach a 150psi compressor to a Hypalon boat, they explode with a really loud THUMP... I scared the poop out of the wild rabbits at my shop..
I'll be letting the glue set for a few days (or longer) before I actually use the boat..
lncoop
Re: repairing a PVC
Actually, I was talking about drying time before applying the patches. The solvents in that adhesive will supposedly eat your boat if they're not allowed adequate time to dissipate.
