nhblock
Thread starter- Joined
- Mar 1, 2012
- 40
As detailed in this thread, I picked up a beautifully-running 1966 Sears/McCullogh Ted Williams 7.5 for my 14' fiberglass dinghy. Now that I have the fuel line issues solved, it's on to cosmetics.
As you can see in the pictures, there are some cracks in the cowl, and even some chunks missing. I came up with (what I thought was) a solution, which was to make patterns and cut some pieces out of plexiglass, then epoxy them in to the missing parts of the cover. However, the pieces are so small that I just ended up shattering the plexiglass (and sliced open my palm in the process).
Is there another, more flexible material that is resistant enough to heat/water that I can use to patch these holes? Or am I just not cutting the plexiglass correctly?
