woodman7975
- Joined
- Aug 12, 2008
- 46
I have attached some pictures of the transom keyhole on my Sea Ray I am repairing. These cracks are the ones that lead me to find that I needed to replace the transom and ultimately everything else. I have just finished sanding the hull and transom and am gettin everything ready to set the transom.
My question is about the cracks. I had planned on routing them out a little bigger on the inside and then filling them with peanut butter when I install the transom. Then routing them out a little larger on the outside and filling them with gel coat, same with the stress cracks around the drain. Is this the right plan of attack?
Also, when I put a straight edge against the area there is a gap slightly larger than 1/8”. I plan on setting the transom with 2x4s clamped with threaded rod. Will this pull the area flat? Any suggestions on getting this area flat? I do not want to run into flatness issues when I put the engine and out drive back on.
I would also love to hear any pointers on getting this area as flat as possible. Thanks.
