Clark Savage Jr
Thread starter- Joined
- Mar 1, 2011
- 14
After peeling back the foam sound insulation in this engine, I found out why the upper and lower cowl sections were separating. Seven of the lugs which hold the joint screws are broken off.
I was able to get the upper cowling to mesh with the lower cowling by tightening cargo hold-down straps around the cowl. It looks like I could simply drill the flange on the lower cowl and insert pop rivets to hold the two sections together.
Can anyone suggest an alternative to this method?
I'd like to add my thanks for all the help so far on this forum. You guys are great and it's a privilege to make your acquaintance. I own a Yahoo group which discusses a particular design of homebuilt airplanes and know what it means to constantly reply to newbie's questions. I appreciate your patience and knowledge, truly I do.
