Replace 305 (5.0LX) with 350 (5.7L)
gjcombs
All,
It's another post on repowering, so I apologize ahead of time. Here's what I need to know:
1. Can I use the parts from my 1994 5.0LX engine on a marine 5.7L long block?
2. Can I use the same Thunderbolt Ignition?
3. Is it worth going to a 350 versus the gain in weight of the engines and HP?
4. For a 1994 engine, should the one I have be a one-piece rear main seal?
5. Can I use the same outdrive (Alpha One, Gen II, 1.50R) gear ratio in going to a 350?
6. Any suggestions or answers that I am not asking the questions yet about, but should be?
Thanks.
John_S
Re: Replace 305 (5.0LX) with 350 (5.7L)
You should consider going with vortec heads for another 30hp. It will require a new intake manifold, and maybe some adjustment to your 4brl carb.
gjcombs
Should the 305 parts be compatible with a vortec 350?
Should a vortec long block come with heads and intake manifold?
John_S
Long blocks typically come with the heads, but not the intake.
The following are things to check, be it vortec or non-vortec:
- If it has a plastic timing cover, a different engine circ water pump is needed to clear it.
- If new engine has a roller cam, your distributer needs the melonized gear.
- If new engine has a roller cam, and mechanical fuel pump boss, you need a fuel push rod for a roller cam.
- If new block does not have mechanical fuel pump boss, need electric fuel pump system.
- While the location of sbc ports hasn't changed, the spark plug location/angle has changed slightly. Check you exhaust manifold part number, to a gen+, or standard head 350. If there is any question on condition of existing manifolds, just get new ones.
- Thermostat housing must fit and hoses clear other items.
- Bracketry attached to intake bolts, if any, would need modification or change for vortec intake.
- If you have a "stove" style choke, need to convert to electric choke for vortec.
- Need a 350 harmonic balancer.
- Carb tuning from 305 to 350 or 350 vortec.
gjcombs
Follow up:
I have a manual choke Qjet 4bbl. What if I want to go to an electric choke? I am thinking an Edelbrock 1410. Should the wiring harness have leads already?
John_S
Follow up:
The edelbrock 1410 is calibrated for BB. It will need to tune it (rods/jets/springs) for the 350. The 1409 is tuned for 350. Not sure if you have a wire in your harness, but if powered from icm, you probably need to run a wire to alt that would have full voltage and current.
