matt167
- Joined
- Sep 27, 2012
- 4,443
Re: replace 4.3 in kind or upgrade to vortec with ramifications/problems?
I would find a V belt pulley that works with the '11 balancer. The '92 engine may run a different balance.. You might be able to have a machinist make it fit.
Oil pan should work if you can get it to fit where you need to. Not sure on any part numbers for the serpentine system, but see if your front accessory brackets will fit onto the new motor. If they do, just take care of the crank pulley and run them
