Replace A Fuel Pump On 1989 110 Hp. Evinrude
BIG-D
ANY ONE HAVE ANY INFO ON REPLACING FUEL PUMP ON 1989 110 HP. EVINRUDE.
ALL INFO IS MUCH APPRECIATED.
pduquette
Ensign
Re: Replace A Fuel Pump On 1989 110 Hp. Evinrude
Hi again BIG-D ! I checked up on your pervious posts and will try to steer you to get some answers ...hope I can help a little ..if you can , add a model # so the gurus will be spicific with answer . I have an '80 j50 so my manual won't help a lot , Do you have a selco / O.E.M. manual ?
Can you give a better Idea as to what the problem with your pump is ? thanks peter
emdsapmgr
Some engines use a simple fuel pump. Your engine has a combination oil/fuel pump which is a little more complicated to install. You might find it easier to replace with a factory service manual. Contact Ken Cook co. in Milwaukee, for an original service manual copy for your engine.
tashasdaddy
loose the caps when posting, hard to read, and considered shouting.
need more info. are you replacing with a new VRO pump, OMS pump, or straight premix pump. does your fuel side still work and the oil side bad?
what is your problem and your goal?
