2002 Crownline 230 BR with 350 mag Bravo III 0m326575
Boat is new to me, previous owner claims no overheat which I now doubt. I have replaced manifolds and risers as well as new impeller and seawater pump. Runs great on muffs however I shut her down when temps hit 180. I took off t-stat housing and to my surprise - no t-stat. The boat has been only in salt water so I took off the water hose connection on the inside of the transom and the passage is almost completely occluded.
My question: should I try to replace the water hose or just go ahead and do a thru hull conversion? I'm not sure I'll be able to fix the hose to be honest - I could barely get the hose connector plate off the transom and even if I get it off I don't think I could get the hose fitting tool to fit without pulling engine.
If I go with the conversion, can I leave the current set-up and install a T fitting or is the block-off plate the only way to go?
Is there a better option? Is there any downside to a thru hull conversion? Are there advantages to a thru hull?
