justthisguyyaknow
Thread starter- Joined
- Jul 13, 2009
- 38
Let me preface this post by explaining I'm not particularly mechanically inclined, and make no claims that I am. I'll be the first to admit by ignorance about boat drivetrains.
The problem is on a Mercruiser 120 4-cyl in a 1973 Starcraft. Ran just fine until, quite suddenly, a loss of power. I shut off the engine while awaiting the readiness of a kneeboarder, and when I restarted it, a noticible loss of power.
The temperature gauge read quite low (and I've since found that the wire to the sender is loose). Therefore, it may have overheated (with a faulty temp gauge, isn't that fun).
So, I shut the engine off as quickly as I could get out of traffic, and towed it to the trailer. I may not know much, but I knew I didn't want to cause any more damage than what was/may have already done.
Took the boat to the mechanic (one listed on the Mercruiser site, and good reviews). I asked the mechanic to check the impeller, and find the cause of the loss of power. Mechanic performed compression test (I hate these, it's like getting a dreaded report card). 115-30-30-115. Darn!
So, I think, blown head gasket. This would cause a loss of power. I'm thinking check impeller (and rest of cooling system and replace head gasket).
Mechanic than does a cursory inspection (through the spark plug holes) of the #2 & #3 cylinders. He finds that there is very noticeable damage to the cylinder wall of at least one of the cylinders. Due to this, he feels my best bet (I'm on a budget) would be to get another engine and have it checked out before installing.
This seems reasonable, given that there is the pronounced damage to the cylinder wall(s). There is also oil on the plugs, so I'd hate to just put a new head gasket on to an engine with lower-end damage (throwing good money after bad).
Obviously, the cooling system needs to be checked out either way (and the temp sender mended).
Now, my apologies for being long-winded. So, questions:
1. Am I right in assuming it unwise to ignore the lower problems in the engine, and simply replace the gasket? I don't mind it using a little oil, but I don't know how long it would really last.
2. What type of tests should I be sure the mechanic performs on my (yet to be located) "new" engine to be sure I don't end up in the same boat (pun intended) with the new engine as with the current engine?
3. Any ideas on where to LOOK for a 120/140 engine?
