willy nilly
Thread starter- Joined
- May 18, 2013
- 6
Hi
ive broken the steering bracket on the transom plate!
I realise I need to remove the engine (4.3 gsi). Obviously the transom plate holds the out drive to the transom.
can I do this without removing the outdrive and just holding it in place once the bolts are put back in? Or do I just remove the leg via the 6 bolts?
im assuming the engine will just unbolt from the hull side and pull out?
many thanks
many thanks
