i replaced the charge coil and the sensor and still have no spark on either cylinder 1987 20hp johnson by the way the coils both ohm out ok what else could it be?? the powerpack is there a way to test or just replace the boat just died at wide open throttle and now has no spark the charge coil ohmed out less than the ok range so i replaced while i had the flywheel off what next??
