Hi to all,<br /><br />Well I'll try to explain, before replacing the ign. module it wouldn't run above 2k rpm and boumced back and forth "slow" kicking in for some reason but deffently not overheating.<br /><br />I replaced the ign. module. Now at different speeds from mid range to wot it just ran badly missing very bad, runing, but missing. I'm not sure which plug or if its both. As yesterday was very windy and rough, I probably shouldn't have been out but I wanted to see if the ign. module had repaired it. The puzzleing thing about it is that it ran fine for 15 to 20 minutes.<br />I checked the temp. of the engine and wasn't hot, I could put my hand on the block for several seconds.<br /><br />I'll try to get out later today to check further like which plug. What other things should I check while out on the water? I have a fluke vom meter.<br />I will check the plugs again but they were brand new and have new plug wires.<br /><br />Thanks,<br />Beck
