zero lash
Thread starter- Joined
- Sep 4, 2011
- 55
I have a 2000 Baja. I replaced both the trim sensor and trim limiter. The trim sensor worked I was able to adjust the gauge. The limiter did not work at all. When I when to adjust it from turning the puck to adjust it it did not work. So I switched the wires did not work. I checked the fuses no blown fuses. It checked for power at the connection and there was no power. My trailer switch on the boat does not work obviously. It don't know where it gets its power from and where to check.
