BROUSSARD2
Thread starter- Joined
- Mar 20, 2018
- 25
after changing my gear shift cable. Ordered the same model as before. Hooked it up the controls. Hooked it up on the motor end, it will shift into forward neutral and reverse but the throttle stops as soon as it goes into reverse. It won't budge. I tried making adjustments but if I adjust it the other way it does the same thing in forward. Motor is a 112 johnson. Boat is a Cajun. Both 1995. Used a cc205 14 ft cable. Not sure where to go from here as adjustments will not work. Any help you can give would be great. I can't find any info online.
