Hi,
I just replaced the trim n tilt pump motor on my 93 Evinrude 90HP.
The motor was about 100% up last year when the pump failed.
I manually lowered to about 80% when trouble shooting it before I figured out it had a dead pump and it remained in that position all Winter.
There is no question that the problem was a dead pump because it's housing was rusted through and wouldn't spin with 12 volts applied directly to the leads.
I was hoping that after installing the new motor it would just start working again but although the motor runs nothing happens at all, no motion what-so-ever and it doesn't sound like the pump is "working on any fluid".
When I removed the old pump motor I had a little fluid leak out but not tons.
I removed the large cap on the resevour tank and fluid started pouring out so I quickly screwed it back on and assumed that there's enough.
I'm thinking the pump unit might be air-locked?
I still have the motor suspended over the transom as I had to pull it to get at the most in-accessible pump bolt.
So now what?
I'm sure I'm 90% there and I'd really rather not enter the waiting line of my local OB shop.
Any advice from knowledgable mechanics would be highly valued.
Steve from NH
So now what?
Steve from NH
