replacement battery size???
bisonfan
looking for adivce on replacement battery size for my johnson V4 115. The current battery is missing tags so I can't determine cranking amps, any ideas on a middle to high end amp battery to replace the current one with? I am thinking 800 cranking amps and 600 plus cold cranking amps might be sufficient.
Chris1956
Honorary Supreme Mariner
Re: replacement battery size???
From my OMC Service manual for a '98 115HPV4 motor: 360CCA (465 MCA) with 90 minutes reserve capacity or 50 ampere-hour.
That is not a high end battery. Most any 24 series will meet these specs.
bisonfan
Thanks for the information, that clears up one possibility!
