Replacement belt size?
KD4UPL
I thought I got the right replacement serpentine belt for my engine but it doesn't fit. Upon closer inspection of all the ordering guides I can't seem to find my combination at all.
I have a 2004 Mag 350 Bravo 3, S/N 0W005823. It has power steering and standard cooling (it sucks in lake water thru the engine).
The old belt is 57-863876-3. The new belt I ended up with that is just a bit small is an 18-15102. Can somebody please direct me to the correct belt for this engine?
Thanks,
The old was 8638763 and new is 865615Q03
The Sierra 18-14102 (105 inch x 13/16) crosses to 865615Q06 (note the 06) which is for a Alpha/Bravo with closed cooling
Dayco belt
104.5 inch 7 rib (13/16) = 5071045
Note 507 for type and 7 ribs and 1045 for the length
Could use Dayco, Gates and go find the length you need
Dayco #
5071055 = 105.5 length
5071065 = 106.5 length
To find the length of you current belt lay on a floor and mark the belt and the floor. Now roll the belt on its back until the mark comes in contact with the floor again. Mark and measure the distance
stang32
the 507 only has 5 ribs. i have made this mistake several times, always forget the correct #
KD4UPL
Thanks,
So if the 865615Q03 is the one I need then that's over $120 just for a belt. I don't buy that many serpentine belts but I wasn't expecting that. I know the belts for my Chevrolet Suburban and Impala are more like $30 to $50.
I was going to replace the one on the boat just as a precaution; I don't know how old it is, I've only owned this boat for 3 years.
Maybe I'll just keep running the old one for while.
achris
More fish than mountain goat
Take your old belt to your local friendly car parts shop and get a Gates belt the same. 1/3 the price, same belt.
stang32
from the gates belt website
Micro-V® Belts Listed by Number
K061037 ............................... 104 1/4 (2649) 40° 13/16 (20)
K061045 ............................... 105 (2666) 40° 13/16 (20)
K061058 ............................... 106 3/8 (2701) 40° 13/16 (20)
K061066 ............................... 107 1/8 (2722) 40° 13/16 (20) K
Fun Times
Thanks,
57-863876-3 should had been Sierra number 18-15100 - Belt
18-15100 Serpentine Belt Replaces Mercury 57-863876 3
Additional Details:
  • Length: 106.25"
  • Width: 13/16"
ModelCID / CylindersYear RangeSerial No. RangeType of beltAlternator / Water Pump BeltBelt LengthPower Steering BeltBelt LengthSea Water Pump BeltBelt Length
350 Mag BRAVO (RWC w / P / S)350 / V-82002 - 20080M600000 & upSerpentine57-865615Q03 #'s 18 21 232704 mm
#'s
18 For engines with power steering
19 For engines without power steering
20 For engines with closed cooling
21 For engines with standard cooling
22 Replacement kit includes 5-3/4 in.(146 mm) pulley & longer serpentine belt
23 For engines with high mounted alternator
achris
Additional Details:
  • Length: 106.25"
  • Width: 13/16"
That's a Gates 6PK2705.. About $30 on ebay. $90 from Merc. 🤦
KD4UPL
Thanks for all the help folks. I ended up getting one from Auto Zone for just over $20. Way better than the $75 or more they want for the "correct" Merc belt.
