Replacement for Trim Controller Volvo Penta AQ DP
speed883
Hello
Since I was affected myself, I found a replacement for the
no longer available trim displays for the Volvo Penta AQ DP drive series.
(VP828731 and VP872498)
Data:
- Large sunreadable display
- Trim limit for SP and DP (can be defined in any position if desired)
- Shows TRIM, TILT and TRAILER position of the drive
- Drive position, display value and trim limit identical to the OEM display
- Five bar display for trim range
- 1:1 replacement
- Display backlight is clear white - only appears blue in the photos
Greetings
Philipp
garbageguy
is it to display the same-old info the existing VP outdrive sensors put out?
speed883
Yes, the Output is ident!
The Bar in the Display are the Leds of the old Display.
Beach Button on DP at 5degrees and on DP at 5 degrees.
I was lucky to find an NOS display about 8 years ago. However this will be of benefits for the early DP290s
