Replacement hub for 67 merc 200 twin 20hp
juicebronco
1967 merc 200 twin 20hp Serial 2249988
The hub is spun, and I can't seem to find a replacement hub locally. Are these parts still out there? Or am I going to need to replace the entire prop?
I know it's an 8 spline shaft because I can count that high.
Any help would be very appreciated.
steelespike
Re: Replacement hub for 67 merc 200 twin 20hp
There is a prop here for $109.
There is a good possibility your old prop has actually worn undersize after all these years.
A new prop may be an improvement.
You may be able to pin the hub with a bolt. Maybe if you use a small brass/bronze bolt it will shear
if you strike something and save the gear case.
juicebronco
Thanks, but I don't plan on creating my own shear pin. I can run my 9.8 untill I get this resolved. If a new prop is the only route, that's what I'll do, but the prop itself is fine, it would be nice to just replace the hub if I can.
