crazy charlie
- Joined
- May 22, 2003
- 5,731
One of my 1988 5.0XL 4bbl alpha ,needs replacement.Reputable boatyard has a very clean good running 2003 5.0 2bbl dry exhaust serpentine style from a bravo.He said that it should drop right in with a few modifications,mostly because of the alpha drive.I gave him the go ahead and he pulled my motor yesterday.Put the 2 side by side.determined that the height of the dry exhaust and the 2bbl carb having a spacer plate might be too tight for my engine compartment.Easiest solution looks to be pulling spacers from risers and carb.his tech made a suggestion of changing over intake manifold,carb ,fuelpump and he was still going when i interupted him and said that it seems like an aweful lot of work putting my old parts on this newer motor.he made reference to the new fuel pump being electric which may be an issue as well.Is my thinking incorrect to keep as much of new motor as possible with the least modifications possible and have a more modern setup?? I have no concerns that a 4bbl is much more desirable as we dont travel with the boat.Its more of a summer mini condo for us.What do you guys think?? Charlie
