Replacement Top for older Tri-hull
eterry
Hey guys, my 1973 Del Magic 15' tri-hull still has a bimini top, but it is torn and mouldy. I wanna replace it, but cant find my hull in the search engine for tops on here. The original snapped onto the split glass, I dont see that on newer models. What to do ??
Thanks,
Eterry
tashasdaddy
Re: Replacement Top for older Tri-hull
if you want the snap on, you have it custom made. if you want a bimini, you get the right width, length and height you want.
eterry
Tash which would you recommend? I could order one and the rails?? would fit on my boat? The rail currently on my boat is a single with a short bow coming off of it, so as to support the front of old top. Just tired of getting my ears burnt while on the lake, and dont want to burn wife...too much of a hassle.
Never been in a boat with a top, other than a poonton, so how high would I want this one? Probably not much higher then the split glass? Or high enough so I can stand up?
Thanks,
Eterry
