Replacing 12' dual rotary steering cables
AZangler420
Replacing my steering cables but can't seem to get second one off of motor cause of space. Do I have to lift motor to replace? I have a Skeeter Bass boat, 81', with a Yamaha pro v 150, 85'. Tried uploading pic's but says pics are to big. Any help will be appreciated, thanks
Your picture is blurry. Sometimes you can move the motor side to side on the transom to allow the clearance to remove the cables.
Modern outboards do not have clamps, as they are bolt on. They do not readily slide side-to-side. You may have to back the boat under a garage door header and fasten the motor to the header and unbolt it to remove the cable.
AZangler420
You were right Chris1956, I had to remove the motor. Thanks for advice, got new ones hooked up, now to hook up to helm
