inletlife2015
Thread starter- Joined
- May 1, 2015
- 51
I really could use some feedback on my last question. Thanks in advance for your comments.
I was thinking about not rebuilding the alpha 1 now and just install this outdrive for now. Does anyone see any problems that I may run into with this swap ?
do I have to get the bearing out from inside the boat ?
Nope,.... That bearin' is serviced through the bellows with the drive off,....
The seal is no biggy, it might hold back abit of purged grease, or water if there's a leak,.....
The snap-rings ain't used anymore,....
Anyone have the part number for the seal that goes behind the gimble bearing ?
Waiting on my hinge pin tool to be delivered tomorrow..
To expand a teensy bit on what Bondo said, with sealed gimbal bearing you don't need to install a seal at all.
Should this cause me any issues ?
The fitting in my hand is bigger, came off the bad motor. Should I change the fuel pump or reduce the line ? Don't want to hurt the performance of the engine. I'm learning so thanks for any feedback.
