iowa_guy_45
Thread starter- Joined
- Aug 4, 2008
- 11
I am going to be changing the outdrive on my 1986 Alpha One Gen 1 with a new aftermarket unit. I have had no real trouble with shifting to forward or reverse with the unit I am replacing. What I am wondering is how far would you consider normal to move the throttle forward before it shifts into forward gear? Currently mine will go into gear smoothly at about 1/3rd throttle maybe a little less for reverse. I have read about replacing the lower shift cable and making the adjustments but just HOW hard is this to do? Should I just replace the cable and be done with it? Any suggestions with replacing the outdrive or the shift cable to make it an easy transition?.......Thanks in Advance
