DamianJP
- Joined
- Mar 25, 2008
- 612
Hey guys
Im still working with my 1977 55HP Evinrude , slow going but making small progress.
To bring you up to speed please read this forum to give you an idea of what I'm doing.
http://forums.iboats.com/showthread.php?t=470721&highlight=DamianJP
Got the head off and starting to think of what the engine needs. I peaked into the exhaust area and saw the pistons are fine and I was set on just rings but I'm thinking while Im in there to do the needle bearings on the crank and piston swivel area. Also thinking of doing the main bearings at the top and bottom of the crank. I have some questions so bear with me abit , Ill keep it as neat as possible. Ive never done rings/bearings.
1)I see there is two diffrent types of rings standard and .030. How do I know which I need?
2)Do I need to hone/de glaze the walls?
3)I have a OEM manual that focuses on this engine only, how hard is it to do the needle bearings? Both the crank and swivel?
4)How hard is the main bearings at the top and bottom of the crank?
I mean I don't know if it needs new bearings or needle bearing but I was thinking its a 1977 and Im unsure of if it had a rebuild since but I figured while im in here to do it. Sometimes I go overkill on the preventive maintenance so let me know what you think.
Thanks again,
DamianJP
Thanks again,
DamianJP
