Flynny
Thread starter- Joined
- Jul 22, 2011
- 86
I'm planning to replace my trailer's barely-working drum brake system with surge disc brakes. It's time for them to go.
I would like to get Kodiak disc brakes after seeing almost everyone recommend them. We launch in brackish water so corrosion is a concern, but as long as I'm diligent with washing the trailer after coming home, non-stainless parts should be ok for a few years right? Will this kit work? I believe I have a 3,500LB axle with 10 inch drums and a 14 inch hub, but I took some pictures for confirmation.
As far as the coupler, there are so many different manufacturers and designs, I wanted your opinions on which are the easiest to use and work the best.
Pictures: (this is the good side)
http://puu.sh/tkph
http://puu.sh/tkp5
http://puu.sh/tkpK
http://puu.sh/tkpu
The rim size is a little confusing because the tire says to mount on a 14 inch rim, and later says do not mount on 14.5in. But my measure showed 15 inches across the rim, where is the rim measured from?
http://puu.sh/tkph
http://puu.sh/tkp5
http://puu.sh/tkpK
http://puu.sh/tkpu
