Well, I've had the new boat home for almost a week now and today was a good day for addressing a known soft spot in the floor. After tearing out the section that I knew was bad, I found a lot more wet plywood and have decided to go ahead and replace about 3/4 of the decking. I also went ahead and took all of the old carpet out. I think it was trapping moisture within the decking.
One of the stringers has a some rot in an isolated 6 inch area where the decking meets the stringer. Since the rot is isolated, it seems too much to tear out the entire decking and replace the stringer. Thoughts? Also, I noticed that there was a moist petroleum/greasey like gel residue on the bottom side of the decking. Is this an issue?
