Re: replacing elect fuel pump w/ mechanical one?
I wouldn't think that the lobe that actuates the arm on the pump would not be present. There might be a rod that is missing, but a junkyard motor would have one for cheap. I trust electric pumps, so I wouldn't change it, but if you really must, I would go buy a marine mechanical fuel pump, take the block-off plate off and clean the block up nice, then put the mechanical pump on without the gasket, or buy a separate gasket, just snug the bolts up so they dont mar the new pump. Bump the motor over and see if the diaphragm moves. If it does, take the pump off and install it coreectly and route your fuel lines. If it does not, this way you can take the part back. They won't take it back if it has been installed, so this is why you don't sqush the gasket or mar the pump with the bolts.
