Replacing exhaust manifold on 4.3l V6....
parttimr
Ok for fear with getting flamed for looking other than the Mercruiser OEM has anyone got thoughts on the HGE brand? Looked at thr Osco/Barr and they are higher than the OEM. Port side has a slight crack so want to replace it before our short season starts and now temps high enough to drain it down to do the work. Only changing the one due to the crack and was wondering can al the bolts be re-used. Either way will use the OEM mercruiser gaskets. Thanks for any and all thoughts.
tpenfield
Re: Replacing exhaust manifold on 4.3l V6....
Price and quality usually correlate, but not always. . . I have not come across HGE brand, but with marine exhaust manifolds . . . 'better' is critical. So, hopefully someone will have some direct experience to share.
NHGuy
I opened a package with HGE exhaust manifolds in it and changed my mind. They are very rough castings. I opted to spend an extra $50 or $70, I think. I normally buy mailorder and wait for best price, but it was July so I bought the parts. This was two or three years ago. I bought OE and I'm very pleased. I've had them off a couple of times for various other reasons. They are really well made.
By the way. You can ease the aching back of installing them by getting a couple of extra length 3/8 bolts and grinding the heads off. Once you are ready to remove the exhaust put the headless bolts in 2 of the exhaust manifold bolt holes, then undo any remaining bolts and slide the heavy manifold off.
They work equally well for installation to line up the gasket and the part for installation. On install just put the manifold bolts on part way, then take out the headless bolts. You might need to wiggle the manifolds a bit to be able to undo the headless bolts. If there's enough room to use it, you could even put a screwdriver cut in them.
FishHog
I put Aluminum HGE on my 4.3L a couple of years ago. I thought the quality was great on the ones I rec'd.
parttimr
Thanks for all the responses but am still on the fence. Can get OME for $223 but shipping in $60. Going to check with local shop to see what they can do. Was told to stay away from GLM and Sierra so thought about the HGE. Barr and Osco are even more than the OME.
