Replacing Gasket on johnson OB fuel tank
marcusknight
I am replacing that gasket that connects the fuel line assembly to the tank. Its a rectangular gasket. My question is, does anyone use any type of sealer, permatex, loctite, or anything else with this? The part number is 0310984
SweetD
I've replaced that gasket and the o-rings on both of my older OMC fuel tanks after the older one leaked fuel all over my boat deck by essentially pumping itself dry, not pretty! There is a nice tutorial here if you find you have the same issue:
http://www.oddjobmotors.com/tt4_singlelinetanks.htm
Good Luck!
Dave
Rustywrench
Good post SweetD. The BRP gasket is now Viton material. That's why I said an adhesive would do no good. If you order the Sierra #18-2881 they are still cork (by appearance?). Something could be used on them. I still have some OMC cork ones, but have never used anything on them. No RTV or rubber based adhesives & you noticed Art Sesselburg (RIP) mentioned all vapors needed to be gone.
