hd883chopper
- Joined
- Sep 14, 2010
- 41
'89 Volvo duoprop geared for a V6 now has a GM V8 350 cui. 21' Rinker Cuddy
Hello everyone,
I was wondering if I could get some advice. Should pursue this or not? I bought a nice rig last year, it has a Volvo outdrive with a GM 350 motor pushing it. It runs good, the only problem is I can only run half throttle. The fella who owned it before me replaced the V6 with a V8 but never replaced anything behind the motor.
Consequently, I have a whole lot of horsepower that I can't use because all I do is tach up. At first I thought the problem could be fixed with a prop change. I've learned its not that easy. I've got mechanics telling me that a gear change would be necessary.
- Would you experienced folks consider replacing the gear pack?
- Is this risky? Meaning could I be opening up more issues than I could possibly fix?
- Mechanic mentioned that I may have an upper gear set as well as a lower (he hasn't seen it yet). Would an '89 Volvo outdrive have upper and lower?
- Finally, does $1500 sound reasonable for the lower gears? This includes a proper pitched alum prop and labor.
Thanks for any comments or advice!
hd.
Hello everyone,
hd.
