Replacing IAC Muffler
ronaca88
I am doing the first 100 hour service to my Mercruiser 5.0 L MPI
I cant find a dealer in Mexico to buy the IAC Muffler.
Any comercial alternative you suggest? How about just cleaning it?
Thanks in advance guys
Watermann
It's just foam block so I would not use anything that could eat it up or deteriorate the material.
achris
More fish than mountain goat
If you need to clean it and can't get one straight away, then just blow it clean gently with compressed air....
Chris.....
Fun Times
To the left is a IAC Muffler in service for 30 hours. To the right is the replacement.
ronaca88
I looks like in 100 hours I wont have a filter any more. hahahahah.
My engine has the filter outside the throttle body, between the iac and the flame arrestor. I think the model change. It is more like a rectangle, note a cube.
Anyways, I will order a couple (one spare, It will take at least 2 weeks in get in here) and I will clean the existing in the mid time.
Thanks guys for your answers.
Fun Times
My engine has the filter outside the throttle body, between the iac and the flame arrestor. I think the model changed. It is more like a rectangle, note a cube.
Yes starting with serial number 0W650000 THRU 1A299999 and up on the 5.0 MPI's, the mufflers became known as filters and are located in a different area under the IAC motor assembly. Item # 12, http://www.mercruiserparts.com/Show...12840&bnbr=82&bdesc=Throttle+Body(Mechanical)
Digital throttle and shift's do not utilize an IAC or muffle/filter.
