EricKit
- Joined
- Aug 31, 2009
- 81
Hello, I'm trying to replace these bearings because I believe they are bad. I understand I have to pull the engine. I want to make sure I have all my facts straight before I begin and also ask a few questions about the steps.
From this diagram, I am trying to replace number 63.
I think the parts I need are:
Bearing: #11013
Inner Seal Ring # 946242
Outer Seal Ring #958860
U-Joint: I found this link: Is this it?: 3860226 or 897707 from this diagram (I'm looking at the ones you sent me CaptMello also)
I think I found the entire connecting components all connected to each other. Would that make it easier if it's in working shape?
From this thread there are these steps from Don S
Bearing: #11013
Don S said:1 Remove the upper gear box on the outdrive
2. Remove 6 bolts (item #41 in link below)
3. Remove lag bolts holding engine front mounts to stringers.
4. Disconnect throttle cable, battery cables, hoses (Fuel and water).
5. Disconnect electrical main harness
6. Lift engine and move forward to clear flywheel housing out of transom shield and lift up.
http://www.volvopentastore.com/mall/...r/8067_big.png
How hard is the step above?Now you can remove the flywheel housing and replace bearings and seals.
Below are links to the OEM manuals that may help.
Engine
http://www.4shared.com/account/file/...ce_Manual.html
Drive
http://www.4shared.com/account/file/...e6375/270.html
You won't have to reshim anything in the drive, Just don't loose the shims just under the bearing of the upper gear box, and be sure to put new seals on everything.
