burgessm84
Thread starter- Joined
- Apr 30, 2008
- 13
I bought the parts to replace the impeller on an 1998 Mercury 3.3. It's 10 years old but hardly used - and not run at all for at least 4+ years. Apparently the impeller had dry rot, so when I fired it up, the impeller literally disintegrated. When I took it apart there were tiny bits of plastic everywhere and what looked like smooshed up plastic on the impeler liner (round metal insert to the pump housing that the impeller spins in).
It came apart pretty easily and I was all ready to replace the liner but I couldn't figure out how to remove it. Long story short, I ended up breaking the pump housing trying to get the line out.
Question #1: How was I meant to get the liner out? It's all smooth, with nothing to get a grip on?
Question #2: I have a new housing in the mail - how am I meant to push it in? I get the feeling it's going to be a very tight fit. The only thing that stops it spinning is a very small dimple of plastic that fits in a hole in the liner, and a small bent tab of the liner that fits in the housing - so I'm worried that if I lube it up to get it in, it might spin inside the housing?
Two related questions:
#3 - I did not get gaskets - from everything I read it seems that just replacing the impeller is pretty standard. I only took the housing off, so I've exposed only the top most gasket's mating surface. It looks really good. Do I need to use any gasket sealer on this part before putting the housing back on?
#4 - What should I clean the parts in/with?
Thanks for your help - as I've come to expect, my engine repair manual left out some of the details on a really basic job (how to remove the liner, press in a new one), while including dozens of pages on how to tear down the entire engine.
Thanks again,
Mike
Thanks again,
Mike
