OK, I've done the work on my 2005 mercruiser 3.0 for the last 4 years that I've owned the boat. It's now come time to replace the exhaust manifold and riser (I'm in salt water). I've seen a couple youtubes on replacing the manifold and riser, but those were for a v-8 and volvo. The theory is pretty much the same, but they always make it look too easy - like starting with everything close to removed. I've also read service manual 26 and this seems like a doable job. I'm always open for advice, and i guess my first question is where's a good place (besides iboats) to get a complete manifold/riser with all the gaskets for the mercruiser 3.0? I wouldn't mind buying siera, but i want to make sure i get the right one. Would be a big PITA sending this wrong order back!
Second, should I do anything with the carb as it needs to come off? For some reason, i have feeling the carb removal/reinstall is going to be the worst part of this job. Finally, any advice is welcome. If there's a good link for this process, I'd be happy to know about it.
