replacing Mercruiser 4.3 v6 1993 engine with Chevy s10 4.3 v6 1993
dlogvine
No Title
various stages of cleanup
dlogvine
No Title
valve piston surfaces are clean, taking the valves apart
dlogvine
No Title
all valve pistons and Springs are removed, in storage containers, ready to be cleaned, cleaning up the head surface
dlogvine
No Title
finished one head, the other one is done same way
dlogvine
the risers were in really poor shape, once I took of the rubber there was so much rust that parts of the riser started falling off. will get replacement risers
dlogvine
If you are in salt and want to change manifolds, go to the 'dry-joint' manifolds.
If I run the boat in fresh water only, would it be better to use the dry joint riser, or regular one would do? Would the dry joint riser also require me to buy new manifolds?
dlogvine
Got the replacement risers, they are used but in a good shape almost no rust. However left port side riser does not have three side holes for some control module which the original riser had. The question is, are these holes present, just covered with paint or should I drill the new holes and thread them? Otherwise the riser is perfectly matching the old one.
Rick Stephens
Not that I have seen ooodles of risers, but every one I have seen was drilled and tapped. If'n I was wanting to drill and tap my own holes I'd be doin so with a drill press and a depth setting. Then use a standard and then a bottoming tap.
achris
More fish than mountain goat
I'm guessing not Merc genuine then.... Port side carries the ignition module (carbed engines) or the ECU (MPI engines)..... BTW, the mounting lugs for the modules should be on both sides of both elbows. Starboard side carries the shift plate. There is no port and starboard elbow, either elbow can be used on either manifold.
Chris.........
dlogvine
Thx buddy, I was wondering if the mounting holes could have been painted over, so I can drill them openings. will make a picture of the riser, looks like there are little indents on the knobs of the riser, could be the holes underneath. will try it later today after work
dlogvine
No Title
looks like the risers are some generic brand, did not find any brand name stamps on them. I guess I'll have to try to find some place to mount ignition module, if cannot find will drill and tap new holes.
dlogvine
No Title
I've got ano there question about the engine block, was trying to find the year and type of the engine, found the following numbers on it, but could not find any reference on Gmail engines for this number. if anybody could help with identifying the block. the last picture has serial number
achris
Casting number 10224535
1993-’94 WITH BALANCE SHAFT: Things got more confusing with the balance shaft blocks in ’93-’94. All of these engines have to have the two extra bolt holes for the strut bosses and 10 bolt holes for the tin front cover. See photo. There are five castings that may or may not be right:
•All of the 10224534 and 10224535 blocks have the two strut bosses and 10 holes for the front cover, so they will fit everything in ’93 and ’94;
Makes it 93/94 (Gen II. Not to be confused with the Gen II drives). 10 bolt hole front cover means a tin cover :thumb:, not composite :facepalm:....
Chris.....
dlogvine
Chris.....
Im trying to find the matching rebuild kit, they all go by the VIN and not by the casting number. Most of the 1993 kits are VIN "Z". I looked at the chevy VIN identification chart, could not find any info on my engine.
achris
Forget VIN numbers. You need a kit for a 'balance shaft 4.3, 1994 (that includes roller rockers and a roller cam, but NOT vortec heads)'. If they can't work it out from that, find another shop.
Chris......
Here is one I found with just one search. It includes a STANDARD oil pump. Do not get a high volume (or pressure) oil pump, you're not pulling enough revs to warrant it. https://www.summitracing.com/int/parts/fem-mkp-6371a000/overview/make/chevrolet
dlogvine
Thank you, I wonder the kit you found in summit racing shop is not a marine kit. Should I look for marine kit or regular car gaskets would work? Also since the replacement engine has quite a few miles, I've been told at least 120K, I'm thinking about replacing the lifters and possibly the camshaft as well. Also I would definitely like to replace the timing chain and gears. Even so Im trying to go as low on expenses as possible, Id like to get the engine in a decent shape.
achris
Just change the head gaskets and you're done. Use the felpro marine ones.
Rick Stephens
I had to do the same thing with my V6 gaskets, just in reverse. I had a pre-balance shaft block with Vortec top end. Buying gaskets was interesting as the most common kits are either one or the other. You are stuck in the middle as well. You can always get a top end gasket set and a separate bottom end kit, which is what I had to do.
Chris - you are awesome. Your knowledge is scary precise considering you were hatched in Oz :^)
