Willaim Pickard
Thread starter- Joined
- Jun 15, 2010
- 4
I removed the engine and found only one broken tooth on the gear. Adjacent teeth are very slightly worn. My question is : should I change the starter and what else should be changed while the engine is out? There was nothing else wrong that I could tell. I removed the engine because it was making a loud noise on cranking it is a 1994 5.7 L with a bravo outdrive Thanks for suggestions
