Lyndy
- Joined
- Oct 15, 2006
- 437
I am nearing re-assembling my outdrive and want to avoid a problem next time I remove the drive.
1. Is it important I use OEM Bolts for the Exhaust Housing Cover and Pivot Caps that have to be replaced because of corrosion.
2. What if any coating can I use on the above bolts to avoid or inhibit the massive corrosion I ran up against last year when I removed the drive. In particular the Exhaust Housing Cover and Pivot Caps.
