hi all. this was my first boating season. i have an '88 bayliner capri with an 82 mercury outboard (70 hp).
i currently have a 6 gallon plastic gas tank with a screw on/off vent cap on top of the gas cap. pictures below:
i've researched the forum and have read mixed things about leaving the vent open and closed while not in use.. primarily that moisture and rain can get in while it's open so it should stay closed... or the other point of view that it can essentially expand/blow up if it's closed so it should stay open. my tank is primarily in the sun everyday because it would be a pain to carry the gas can in/out every time i use it.. sometimes the tank expands so much that it looks like it's going to blow up, but i usually keep the vent closed while not in use due to fear of getting moisture in the tank.
nevertheless, i figure the best solution would be to replace the plastic gas can with a metal one that has an automatic vent. i have found this old mercury tank on craigslist, and have contacted the seller but haven't yet heard back.. i was wondering if anyone can tell if this is "self-venting"? anything else i should ask the seller, aside from rust? his ad says that it's mixed with the same 2 stroke that i'm currently using. here's a pic of it:
thanks in advance.
thanks in advance.
