Re: replacing plug wires?
what made you think about replacing the wires? I have a 1966 rkl-28b 40hp. Top Cylinder only has no spark at the plugs. I couldn't think of a way to test the different components so we swapped the coil packs and condensers and we still have spark on the bottom cylinder only. This has me thinking it it either simply the connection or the wire itself.
What wires did you get to replace them? It's a bit confusing looking at the parts available.
So, you swapped the coils and condensers. What did you do about the most common cause of no fire--the points?
Anyway, to answer your question, the wires often arc through where they are clamped to the bottom of the armature plate. Just a tiny pin-hole. You must use "wire" wire, that is copper wire core. Car "wires" have a carbon string core and are no good for outboards. Find wire wires at some auto parts stores, especially in rural areas. Or farm supply stores like Tractor Supply. It is used on tractors. A few lawn mower shops stock it on rolls also. And, of course don't overlook the obvious---decent outboard shops. Oops, forgot...iboats has it in 25 ft rolls with a bunch of useless terminals included.
