Replacing power trim lines inside boat
MarkSee
Re: Replacing power trim lines inside boat
Yea; I was just hoping if you had those angels and dimensions it in some way might help get the hose run.
Good luck.
Mark
ricohman
Got it!
I ended up getting a bicycle brake cable run up the other line with loose zip ties. Then an hour of cursing and it is in place.
Now, does anyone have the torque specs for the brass nuts on the manifold? And the torque specs for the bolts holding the anode? And do those bolts on the anode need anti sieze?
ricohman
And lastly, I have read that this system is self bleeding, except when you install new rams. Since my rams probably have some air inside, can I still get away with running the drive up and down a few times?
ricohman
