Replacing reeds
Barnacle_Bill
1983 Merc 150 When replacing reeds, should the reed blocks be replaced too. Or can they be resurfaced using 400 grit sandpaper on a piece of glass?
LubeDude
Re: Replacing reeds
They will clean up great doing as you suggest, I just went through it. Use a generous amount of WD-40 and 400 grit paper designed to be used with water. You will be so surprised to actually find out how "NOT FLAT these can be. I ran them accross some 600 when I had them flat.
Barnacle_Bill
Re: Replacing reeds
Thanks for the relies. That is what I thought but wanted to be sure.
